Bench top lathes 50 mm bore size @ $ 4000/- available
These lathes are made in India and assembled in Fullerton California and has one year guarantee
[QUOTE=Gonzo719993;908200]What is the cost to ship to Ocala Florida?
$ 312 to Ocala Florida including lift gate delivery[ residence]
you need more information please let me know.
Attachment 89970
Hi
All the Seam lathes sent from our California within USA is freight free and only charge $75/- for lift gate delivery for residence
Ali
What is the weight of the 50mm Bench top lathe?
Yes The weight on the 50 mm bench top Seam lathe is 500 lbs
All my sales are to residences, not many to commercial locations. Almost all my customers are working from home
Ali
Can you give us the swing, bed length, total run out (tolerance), and other specs for the lathe? What kind of motor is it, what are the speed ranges, how is speed controlled, etc?
Hi Doug
Total bed length is 43", Chuck to chuck is 25" including One " projection [ teeth, jaws] outside the 50 mm bore on the chuck. extra teeth in tool box and numbered.
lathe swing it is 7" from the center of the bore to the plate and 6" from the teeth [Jaws] to the plate
There are 4 bolts in the hollow part of the moving chuck and 4 L N screws on the bottom. These are for calibrating, tools are provided in the tool box. In cleaning or transportation or for unforeseen reasons I would like you to call for tech support for the first time and I or my mechanic will walk you through .
Regarding the cleaning of the teeth, they are numbered, I would really appreciate a call to tech support to walk you through when the lathe is in front of you. 714-443-8677.
On the speed control the dial is there to regulate the speed. The slowest speed is 45 rpm and it is 1750 rpm motor, these are made to last a long time and if there is a elect surge
the fuse will go off and will not hurt or burn the motor, the fuse is available in Granger or any elect outlet.
You have one year on the lathe manufacturers warranty.
Ali Khan
The weight is necessary either American or Indian made Lathes for its stabilizing effect for glass blowing, scientific or water based items. 200 lbs.The lighter it is the vibrations is there even bolted on the table and the table bolted to the floor is ok for wood lathes which doesn't require the precision, steadiness, to make a water pipe where you fuse items inside to make a beautiful piece without defects that show up when annealing if the lathe even has slight variations.
what make you think that a u lathe is a tank?? serious question, I have one. HSA is not a bench top either. The reason these things start weighing alot more, even with bench tops is because of the bed size, which is a hurdle on the U lathe. My Ulathe is pimp, but your still sacrificing alot of space and shit that make big lathes omfy and easy to work on. I bet this seam is a piece of junk in comparison, but if it works correctly, its probably more comfortable and easy to use than a U.
Like the american lathes.... they are super comfortable and easy to use, but they make a shit load of noise and I hear they dont last long. there are things to consider when jumping at a U lathe as well, of course someone would rather have a U, but I dont think you will find one for less than 12k. whats this machine cost?
I wurk on a pretty old U lathe, and its tanky
Shipped a bunch of them to other khuntries as well
And they show up with straight beds
I wouldn't trust an AZ lathe to do that
I don't trust aluminum beds personally
Plenty of aluminum parts on littons, but I prefer a cast bed or that steel billet one looks pretty sweet
Still like to know the swing.
In a glass lathe swing is the distance from the center line of the bore to the top of fire carriage. This lets me know what size burners I can mount, and what size pieces can be worked... Swing, along with bed length and chuck to chuck length, is one of the most important measurements in a lathe.
In the lathe swing it is 7" from the center of the bore to the plate and multiply by 2 and that's the swing.
lathe swing it is 7" from the center of the bore to the plate and 6" from the teeth [Jaws] to the plate and multiply by 2 and that's the swing.
Thanks Mahmood! That's pretty good clearance, a few more inches would be nice, but it's not a huge lathe...
I see lots of u lathes under 12 k
Seen one for 6 with lots of stuff a state away not long ago .
Thanks Doug
Glad to answer your questions and I hope you are satisfied, one more thing that I need to say is Seam lathes are designed in such a way that you can dissemble and resemble easily with the tools we supply with the lathe and our tech support is always available pacific time except Christmas time when Seam shuts down15th till Jan 10th . but tech support is available. Best competing lathe in the market, quality and price.
Seam
Ali
Maybe once I grab the seam, make some cash then I can afford the baller stats
Once you work on Seam lathe ,you will not want to look at another lathe
I plan on ordering one of these today! I will let the community know how the transaction and shipping go.
Ali -- do you have a website you advertise these on?
Yes I do have .
My profile on this forum has a lot of information that is educative.
website-: scientificequipmentandmachines.com
Ali
I have looked over the site Ali, I would suggest adding more tech specs and pricing on the site if it was up to me. That will allow your partons to get more information without having to call you and bug you as much. It would save you a lot of time trying to explain the simple things. ;) The lathe looks good though and from what I can see in the posts here, it will be one to think about getting for myself in the future.
Its a good idea, never thought about before as my Seam lathes were selling good referred by my satisfied customers, I do get a lot of calls its mostly tech support . I should have the tech information on the website.. thanks.
cc-: Gonzo719993 bought a Seam bench top lathe ,he received it last week and he is one satisfied dude
Ok... So she is on her way.....
Yes its on the way , you can track the lathe Saturday or Monday.
