Billyjay's progression
So I got my studio set up about a month ago I don't get much time to go out there because of work. I figured I'd start this thread need as much advice I can get can't learn but so much off of YouTube Attachment 90979Attachment 90980Attachment 90981Attachment 90982
Re: Billyjay's progression
Looking good for a months time on the torch! Keep at it and read thru the tutorial section here as well as the newbie section. Make everything!
Thanks alot I'm definitely gonna keep it up its alot of fun here's two pendents I did tonight first try on an eye
Attachment 90998Attachment 90999
A little project I did yesterday added a bead door to a old top loading kiln someone gave me and I order some things to make a controller for the kiln Attachment 91038Attachment 91039
Little more stuff I was having problems not having oxygen all just got a homefill will be practicing more now
Attachment 91490
Attachment 91491
Attachment 91492
Right on man, looking good
Thanks a lot buddy trying to focus on just w&r i wanna build consistency
Billyjay
i find that with the W+R i really like the look of alternating the direction of the rake. so go down first. then right next to it swipe up. then down again. and more is better. make them tight together. gives more little details.
Alright cool ill give that a try tonight
The one on the left I tried alternating directions when I raked it it's a lot harder to rake away from yourself guess i had it to hot and pulled it out some Attachment 91539
Shaping looks good.
Random patterns are cool IMO
If you want uniform, u could rake one way leaving enough space for rakes in between, then switch directions, and rake the opposite. Giving you the chance to rake toward yourself the whole time
Yes work on size consistency. Use a ruler. Try keeping your vertical lines straight to. Practice spinning with your hands evenly.
Work on small holes and even depth in your pushes.
Thanks for the advice guys ima try to do some stuff tonight
I managed to keep the reds ones a bit straighter just need to keep practicing
Attachment 91546
Nice. You might want to stick to blue because it costs less and easier to use. But you handled the red nicely.
Billyjay
Attachment 91546
blue one on the end looks best due to the most details, take some time to work on your spoon shape as well.
It's Asian striking red it's cost the same as the blue the blues is a lot easier to coil onto a blank though and I probably should slow down some it was taking me like and hour at first to make one now it's like 30 min I probably shouldn't be worried about speed yet
Very nice. Doesn’t it take a long time to strike that color?
It's the first time I've used it but it seemed pretty easy it was mostly red by the time I was done working it except in the middle I left it in the kiln on 1075 for 45 minutes or so and it was all red I got it from mountain glass don't know if that matters there a 50% off sale all month on Asian glass
Billyjay
thats pretty standard strike range / times ive found for most reds ive used... like tags elvis.
I use North Star ruby and it’s 1200 degrees for 20 minutes.
1075 for 45 minutes and you get red like that? I’m going to try. I just ordered some because northstar ruby red seconds were out of stock.
After a few hundred it will be a lot faster.
Most of it was red by the time I was done working except a little bit in the middle than ya 1075 for 45 min you might be able to do it shorter I just didn't look at it till 45 min and ya I just need to keep practicing I'm starting to have a lot of spoons I should go try to sell them I don't feel like there good enough yet but I see worse stuff in headshops all the time
bro. bring them to a shop thats kinda far from your house.... this way if you "embarrass" yourself it doesnt matter going fwd. also just sell them stupid cheap. if it smokes... someone will buy it for a couple bucks anyway.
i saved ALL of my crap first spoons and chillys for concerts. sell them for 5 bucks in the lot. pays your beer tab at the show. plus if we are going somewhere. bring the piece. smoke it till ur done. throw it out if you cant bring it with you.
Thanks for the ideas I have a case set up I didn't put anything wonky in it hopefully I have some luck
[ATTACH=CONFIG]91684[/ATTACH.
those look good. totally sell able
I wanted to try to make something a bit bigger didn't come out bad for the first time using a joint
Attachment 91786
Another try this ones 8 1/2 inches tall it cracked on me when I was doing the joint I was able to fix it Attachment 91809
I made a reamer today first time I tried making something outta graphite i cut a piece off a old marver that came on my torch when i bought it i think it turned out pretty good
Attachment 91877
I'm waiting for new hoses in the mail I havnt been able to play on my torch decided to finish off the hunk of graphite I had I'm stoked to try them out first reamers I've had
Attachment 91886
Nice looking tools! Most reamers are octagon shaped, I’m interested to hear how your round ones perform.
