Results 1 to 8 of 8
Thread: Pyrex/Simax
    Default Pyrex/Simax
    Couple of questions about pyrex and simax.
    Can you work pyrex and simax in the same piece/work them together?
    Is everything that is pyrex compatible simax comatible too vice/versa?
    Which would you say is better?
    Thanks,
    Squirrel
    Dec 2006
    Tyrone, PA
    Default Re: Pyrex/Simax
    afaik they are both borosilicate and have the same coe therefore they should both be compatable with each other. I'm sure there are people that work pyrex that use the same color company as those that use simax. If the color is compatable with both then they should be compatable with each other.
    As for quality I have no clue.
    Jul 2006
    everywhere
    Blog Entries
    1
    both are good quality glass although i haven't tried pyrex since they stopped making it domestically. in my experience simax moves a little bit faster. like gravdigr said, they are completely compatible with boro color and each other.
    "Scientists proposed that male lion's skill at ambushing prey in dense vegetation was previously unknown because of scientists' fear of being ambushed by male lions in dense vegetation." Harpers, findings, may 2013
    corning 7740 Pyrex and Simax's 33coe glass _SHOULD_ be compatible, by looking at their COE, but if in doubt don't mix them.
    Color wise, it should all work the same.
    -Doug
    Clear to clear, you may be able to SEE the difference. Like if you add a bunch of clear simax over a pyrex honeycomb (or something like that) Or if you encalmo a pyrex tube to a Simax tube you may be able to see the line. Other than that they are compatible. As for one being stiffer than another.... that's a good question.
    Wisconsin
    My opinion, I worked both the domestic and made in japan pyrex for years. When one gets use to a certian brand, its hard to switch, even if theirs no noticeable difference in working properties. They both act the same to me, except kimax, I've always liked that, so smooth, and buttery, but now I buy in quantitys that are less than a case, so I can usually expect more scratches on them, any brand bought that way. Glasscraft still sells pyrex in increments of 2,5 and 10 lb bundles, I keep all brands on hand for different applications, my previous post in another thread, I think pyrex honeycombs better, but to many variences, kiln temp and time in affects the whole process in the end.
    steve
    Damn, I didn't know there wasn't any domestic pyrex =/.
    Also, this may sound stupid, but is the term lampworking referring to anything made with torch?
    in the desert
    yes, lampworking referrs to anything done with a tourch, or any work completed when illuminated from an authentic tiffany lamp.
  1. pyrex softer than simax?
    By STROKER in forum Glass Discussion
    Last Post: 03-19-2012, 07:02 PM
  2. FS: Corning Pyrex and Simax Glass, Goggles and book
    By pipeshawk in forum Member's Glassifieds
    Last Post: 01-06-2012, 08:27 AM
  3. Pyrex 1/2 off sale
    By ALIEN! in forum Member's Glassifieds
    Last Post: 02-02-2010, 12:15 PM
  4. Pyrex vs. Simax (how color react I/O)
    By willyoung in forum Glass Discussion
    Last Post: 04-17-2007, 02:42 PM
  5. pyrex?
    By max16o2 in forum Glass Discussion
    Last Post: 04-17-2007, 08:24 AM
