Results 1 to 14 of 14
Thread: Help with heat resistant glue
    Jul 2005
    Jacksonville, Fl
    Icon5 Help with heat resistant glue
    I just took on a project for 1000 glass marbles with flat backs to attach to a kitchen backsplash. The marbles need to be glued to the glass tiles allready on the backsplash. My question is does anyone know of a glue that drys clear and is atleast heat resistant enough to stand the heat from a stove top. Im sure the heat dispurses very quickley from the stove top but I dont want these marbles falling off the backsplash when they start cooking. Any input or ideas are most appreciated. Thank You in advance. Peace.
    _______________
    Peace
    - Matt Hess
    Default Re: Help with heat resistant glue
    Try E6000 it's an air cure, one part, silicone based, epoxy. It dries clear, is formulated for glass, stays somewhat flexible, and handles decently high temps. You may want to test a few before installing the entire project.
    Your other option would be plain old 100% silicone or maybe a 2 part epoxy...
    good luck, sounds like a big project... gonna take pics?
    -Doug
    VA
    I use a UV adhesive made by Loctite. It is Loctite 352. It is a structural adhesive and sets by UV light and/or heat.
    Jul 2005
    Jacksonville, Fl
    Grey u have a site for the E6000 glue I can order it from? Thanks
    _______________
    Peace
    - Matt Hess
    uv glue is good but brittle. E6000 would hold just fine and "give" a little if knocked around before "popping" off.
    Jul 2005
    Jacksonville, Fl
    Thanks for the info guys keep those ideas coming please.
    _______________
    Peace
    - Matt Hess
    Jul 2005
    Jacksonville, Fl
    You guys seen this before.
    http://www.franktross.com/weld_glass.asp
    its called weldbond
    _______________
    Peace
    - Matt Hess
    Western Pennsylvania
    UV glue is NOT heat resistant. I do repairs all the time- when something is UV glued to a mirror, I use a blow dryer to soften the glue and remove the piece. In a kitchen application, you may want to find a way to grout the marbles on to tile or hardibacker board- it would a be more permanent installation.
    Jul 2005
    Jacksonville, Fl
    You the man Mr.Wonka. Peace
    _______________
    Peace
    - Matt Hess
    North Conway NH
    UV349 has an outstanding ability to cure through large gaps and to cure to a hard, dry surface that is water clear.
    Color: Optically Clear
    Contents of Bottle: 1.69 fl oz (50 ml)
    Net Weight: 1.8 oz (51 g)
    Additional Product Information:
    Strength retention on exposure to moisture or humidity is excellent. When cured, it also has a high degree of general environmental durability and resistance to discoloration on aging. Cured adhesive temperature resistance is -65 to 266 degree Fahrenheit (-54 to 130 degree Celsius).
    http://www.technologylk.com/
    they also have other glues and epoxys, give em a call bet they could help ya out
    also http://www.bohle.de makes glass bonding/uv glues
    ask at info@Bohle.de
    You should be able to pick up E6000 at a good art or hobby store, sometimes places like Home DEpot or Lowes will carry it.
    Oh... on that note.... you might look into JB weld... they might have a clear product.... just look around the glues section of a local hardware store.
    -Doug
    Aug 2005
    Jacksonville Beach Florida
    hey matt ever thought of hextol? Don't know how it stands up to heat but it's damn strong! Stronger than glass..I've heard. Try finding it at olympic color rods.
    Jul 2005
    Seattle
    A quick search of www.mcmaster.com didn't turn up anything. You can also try www.globalspec.com....
    -indo
    Momka's Glass Kicks Borosilicate Ass
    Jul 2005
    Jacksonville, Fl
    Thanks for all the feedback guys it helped allot.
    Peace
    _______________
    Peace
    - Matt Hess
  1. Fire-resistant hoodie by Redwood Empire Glassworks
    By Cheese glass in forum Member's Glassifieds
    Last Post: 01-13-2012, 03:29 PM
