drew fritts made that? doesn't look like the ones i bought. his molds rock, but not sure this is the real deal or more ABR snake oil
Are these worth it? It has both sizes on the same handle. Am I better off just getting the separate ones or will this do?
Here is the link
I have seperate molds for those sizes. That might be a cool upgarde.
E
Drew designed the infinite rim and Dan Grumbling makes them. The mold in question at ABR is made by Dan and works well. But personally I prefer the separate mold for each size. Sometimes I use the bottom of the molds for shaping and with the 2 in 1 there is a hole.
JK
i use a 4-in-1 and it works great. http://www.arrowsprings.com/4-in-One_Marble_Mold.jpg
http://www.etsy.com/shop/fadedglassworks
irony = smoking a cigarette in order to check your ventilation system.
The bump style marble molds look kinda groovy.....Why would you want a hole in the bottom of your marble mold?
you don't want a hole in the bottom.... not ideally.
It will still work on the size marbles it's made for, but you don't get a bottom for shaping smaller marbles....
I have both sizes as separate molds, wouldn't consider that an "upgrade" at all, it's more of an economy issue if anything.
Also, I use water in my molds quite often, so that would be worthless then.
-Doug
love my 2 in one .... very slick movement when shaping marbles that are 1.5 inch plus... use the large to get things shaped and then the smaller the crispen the edges... 2 in 1 is worth the pennies for sure!
it's worth what you pay I guess, I prefer 2 molds in 2.
I can't speak from experience using this mold but I find myself using the bottoms of my molds often. I'd get separate ones
I own that one. I have a regular marble mold that I use when I make smaller marbles, but that isn't very often. The 1.5" measurement is the widest part of that side of the mold. I can shape 1.25" marbles in it no problem. If anyone has my book, I use that exact mold quite a bit in the book.
It's well worth it I think. I can think of one or two times I wish it had a bottom, but I've made hundreds of marbles since I got it, so I think that's a pretty good ratio.
having the solid bottom means you can use it to push spirals too. With the hole you risk smooshing the glass through.
I've got a fritts 4 in 1 for what it's worth. It was an upgrade from ABR's 3 hole mold, which is nice too, but the Fritts model was worth every penny.
