Results 1 to 7 of 7
Thread: GOG Joints??
    Feb 2010
    Default GOG Joints??
    whats the most common size of GOG joints? Wanting to order some and was goin to try to make some slides for first time. Didnt know which size is more common or if one is at all. thanks yall
    ~Legalize Freedom~
    Follow the Mobile shop Adventure!!!
    My Facebook!
    My blog!
    My etsy!
    Jan 2008
    Boulder
    Default Re: GOG Joints??
    Quote Originally Posted by Nomad View Post
    You just don't get it
    get heady
    Mar 2010
    for the slides (bowls) most people are using 14's. because the standard now is a 18 female on the tube, with a 18 > 14 transition downstem that takes a 14 slide. hopes that not confusing, but 14 for the slides.
    Nov 2005
    Portland OR
    18mm and 14mm. Stores seem to order both sizes, some more than others. Def nice to have both sizes on hand though.
    "Reason well from the beginning and then there will never be any need to look back with confusion and doubt."
    H. H. the Dalai Lama
    My Glass
    Dec 2007
    Arid-zona
    order the 14/23 and 19/26 males.
    most production glass on glass comes with the bushing adapter/transition/ recessed downstem. these downstems have a 19/26 male, with a recessed 14/23 female set inside the downstem.
    they are the most common so 14/23 males are going to sell more. that tokecity thread is relevant, but only covers the more elite glass purchasers, who prefer the 18mm bowls (19/26) because they offer a higher flow.
    its good to make both, as was said above, but truthfully the 14's are more common.
    Feb 2010
    Well i would have guessed wrong, I assumed the 19/26 would be more prevelant because of higher flow. Im glad I asked thanks for the link and the Info yall.
    ~Legalize Freedom~
    My Facebook!
    My blog!
    My etsy!
    Dec 2007
    Arid-zona
    there are more production companies using bushing adapters than anything else. therefore the 14/23 is more compatible, and people have more of that size, but people with higher end works tend to have pieces with 19/26.
    i prefer the 19/26, and its all i use on my work. i'd say make both sizes, you can't go wrong.
  1. Weird GoG fitting.
    By ReLo442 in forum Glass Discussion
    Last Post: 04-22-2011, 04:37 PM
  2. GOG fittings....is this normal?
    Last Post: 02-25-2011, 08:54 AM
  3. GoG tools
    By jr23 in forum Member's Glassifieds
    Last Post: 02-26-2009, 02:17 PM
  4. GOG joint sizes???????
    By petto in forum Member's Glassifieds
    Last Post: 10-14-2008, 07:28 AM
