Page 1 of 2 1 2 LastLast
Results 1 to 20 of 33
Thread: Low cost manifolds (DIY)
    Western Pennsylvania
    Default Low cost manifolds (DIY)
    Hi Folks.
    In the past people have asked how we set up the manifolds under all of our benches. Below is a diagram for low cost manifolds (mainly parts from Lowes or Home Depot) in which you could just cut a hose anywhere and insert these in with a couple of hose clamps.
    I hope this helps some of you!
    Tom
    BTW- The propane and oxygen fittings (that the regulators plug into) are available through your gas supplier.
    Nov 2007
    Default Re: Low cost manifolds (DIY)
    I wish I could rep you for this, but I gotta spread it around some more. However, this is definitely a knowledge rep worthy post.
    The most helpful bit of advice I've ever received:
    Quote Originally Posted by mer View Post
    -don't give up. it's more than a job, it's a lifestyle.
    www.nocoastglass.com
    Oct 2007
    DFW, Texas
    Hey, that's how I built my manifold. Easy peazy and it allows me to have shut off valves for my hand torches.
    Dec 2010
    Tucson
    I built mine like this too but had troubles finding the npt to oxy and npt to prop parts. Where do you guys get em?
    instagram pics : http://instagram.com/zombie_hand_studios
    Josh Forche
    Zombie Hand Studios
    Tucson Arizona
    520-272-4578
    josh.stackt@gmail.com
    Quote Originally Posted by Forche View Post
    Try the welding shop, if not try doing a search for western enterprises.
    I have a similar system but I have quick connects at the end of everything and don't have the shutoff valves.
    E
    The gas/oxygen parts are called "B" fittings.
    You'd probably want a Western Enterprise P/N (#xx) (also Radnor):
    #33 - 1/4 NPT to B LH (fuel gas)
    #32 - 1/4 NPT to R RH (Oxygen)
    These are listed in the Western Enterprises and Radnor catalogs under Fittings / A,B,C,D / REGULATOR OUTLET BUSHINGS
    You can get them from any welding or pipe fitting supplier that sells welding fittings.
    They shouldn't be more than a buck or two each.
    Apr 2010
    Bloomington, IN
    ABR IMAGERY
    812-339-0147
    866-342-4764
    Twitter: @ABRDave
    Instagram: http://instagram.com/abrimagery
    Oct 2007
    DFW, Texas
    Oh oh,
    totally unrelated, but do you happen to carry the hose barb fitting for the air inlet on Herbert Arnolds? I need one. It is just like the fitting on the torch end of the HA regulator except the threads are reversed.
    Please say you have one.
    I don't use B fittings on the ends. I purchased the fittings that mimic your gas bottles so you can screw a regulator directly into the manifold.
    During AGI when we have 20 torches on one line alone, I use a main reg at the tank and charge the line to 60 or 80 pounds. Individual work stations can use the regs on the manifold to set any pressure they want.
    I forgot the name of the regulator fittings, but if you tell your gas company what you want to do they will get you what you need.
    Tom
    Dec 2010
    Tucson
    Wow guess i didn't really look that hard then. Thanks for the replys- the welding shops didn't carry em so I had to make a couple with saws and welding - fun fun fun. Then I see there a buck from ABR
    Josh Forche
    Zombie Hand Studios
    Tucson Arizona
    520-272-4578
    Apr 2010
    Bloomington, IN
    We don't have any actual "Herbie" parts from Arnold, but I think the air hose is a 1/4" barb.
    ABR IMAGERY
    812-339-0147
    866-342-4764
    Twitter: @ABRDave
    Oct 2007
    DFW, Texas
    Nope.
    It is metric, and it is a lot bigger than 1/4inch.
    Too bad. Guess I have to order one from Germany.
    Apr 2010
    Bloomington, IN
    The gas ones are, but the barb for the air hose, which is measured by it's id, is for sure 1/4" I even just put a tape measure to one to be sure.
    If you are talking about the hose barb for the oxy, it's much bigger
    ABR IMAGERY
    812-339-0147
    866-342-4764
    Twitter: @ABRDave
    Oct 2007
    DFW, Texas
    I don't think we are talking about the same thing here. My air intake (lower one, right hand side when viewed from behind the torch) is way bigger than my oxy intake. Maybe it is different on the new torches but I don't see why it would be.
    Are you mixing the air and the oxy intakes up? Luft is air, the bottom one, which should be the same size as the gas (at least the male part is if you take the barb off).
    Also, these are German, and they use the metric system, so none of the fittings are 1/4 inch. The ID of the oxy hose barb on my torch is 5mm, or about .2 inches.
    I'm using 3/8 hose on my old style Herbie for air. Do you have the nut and just need a barb?
    E
    Oct 2007
    DFW, Texas
    Edit
    Wait, I think I know what you are using. So I can just get a 3/8 inch female with hose barb and use that even though the the male part on the torch is a b style fitting (meaning the ball and cup parts are compressed together)?
    If that is the case then sweet, thanks for the info.
    OK, I just got the part number for the regulator fittings:
    Item Number: B-42 - WESTERN ADAPTER CGA510 X 1/2NPTM
    Item Number: B-52 WESTERN ADAPTER CGA540 X NPTM
    Tom
  18. #18
    Jul 2005
    was Belize now UK :-)
    Not only, but also...
    It ain't where you're from, it's where you're at.
    Really.
  19. #19
    Apr 2010
    Bloomington, IN
    whoops, sorry, i did have them mixed up.
    ABR IMAGERY
    812-339-0147
    866-342-4764
    Twitter: @ABRDave
  20. #20
    Mar 2009
    Salem, Or
    Quote Originally Posted by Mr Wonka View Post
    Tom
    I have worked at a propane/gas grill place on n off for the last few years.
    The male portion that screws into the bottle is called a POL fitting (if threads inside the valve) or Acme nut if outside, hand tighten deal. The other part is just called Female POL which works for both of the male mentioned because the reg POL goes inside threads, the ACME goes on the outside threads.
    http://www.amazon.com/Heater-F273791.../dp/B005R21ROO
    Im sure there is a better place than amazon to get them, just wanted to put up a link.
  1. Low cost manifolds
    By Mr. Wonka in forum Glass Discussion
    Last Post: 02-25-2013, 12:21 AM
  2. WTB manifolds
    By rye in forum Member's Glassifieds
    Last Post: 05-14-2009, 03:45 PM
  3. Low cost shipping solutions I've found...
    By THAT Guy in forum Glass Discussion
    Last Post: 07-16-2008, 09:14 AM
