Low cost manifolds
Hi folks.
If any of you need manifolds to run multiple torches off of one regulator, go to eBay and search, "1/4" manifold" to find something like this.
With some extra fittings (ball valves / barbs / nipples / 1/4" NPT to "B" fitting, etc) you will have an affordable way to expand the number of torches per regulator.
I hope this helps some of you : )
Tom
Re: Low cost manifolds
that's what I use for my lathe... well, an aluminum version of the same.
I would suggest you get some 1/4" NPT to 1/4" barb fittings, some 1/4" NPT to B fittings, and some 1/4" plugs. You'll also need 2 3/8" plugs and some 3/8" hardware for end inlets...
Total cost per manifold was under $30 when I did it, and I can hook up 6 torches
Just to confirm so I don't do something stupid. Aluminum is ok material to use for a manifold block for oxygen or propane? Also, it sounds like your plugging 3/8 inlets and using one of the 1/4 outlets as the inlet, is that correct?
Orion Glass Works
Yes as long as its regulated pressure not tank pressure
I think ideally you would supply your manifold with a 3/8" hose then branch out with 1/4". If you don't have 3/8" then buy a 1/4" to 3/8" adapter or like you said plug the 3/8" and use one of the 1/4" for your inlet.
By Mr. Wonka in forum Glass Discussion
Last Post: 04-01-2015, 05:03 PM
By rye in forum Member's Glassifieds
Last Post: 05-14-2009, 03:45 PM
By THAT Guy in forum Glass Discussion
Last Post: 07-16-2008, 09:14 AM
