Results 1 to 6 of 6
Thread: Need Help with regulators
    Feb 2013
    Default Need Help with regulators
    I have a slight problem.
    I brought a Twin regulator pack from Wale Apparatus. It came with one fuel and oxygen regulator and a set of flash back arrestors. I set up the regulators and have everything ready to go..
    but I cannot set the PSI on the oxygen or the fuel regulator! I do not know what I am doing wrong.
    I loosen the knobs that set the PSI, turn the oxygen and fuel valves on the tank on (turned until they stopped). Then I went to turn the knobs on the regulators to set the OXY to 5 and the fuel to 3. But I turned the knobs ALL the way to the left (they were almost going to fall off) and the lowest PSI I can get on the OXY was 90 and on the fuel 20.
    What am I doing wrong? Why won't the PSI decrease further?
    Default Re: Need Help with regulators
    Try turning the regulator screw clockwise to set the line pressure for the torch.
    E
    Nov 2009
    Asheville, NC
    You have to have the screws backed out like almost all the way when you turn the pressure on. Then you crank them in to raise the pressure from zero.
    Quinn The Eskimo Designs
    Facebook [Most up to date work here usually]
    "Flower implosions are for sissy behoches, I am not a sissy behotch."
    -Funksizzle
    Aug 2011
    Eugene, Or
    Quote Originally Posted by hh080311 View Post
    Open the valves on your torch to decrease the pressure on your regulator gauge. The psi will go up with the valves closed, but it won't "appear" to go down.
    Distributor of Gentec Products for the Glass Blowing Industry
    Contact me for everything Gentec!
    Eric F.
    Area 541 LLC
    Eugene, OR
    (541) 335-9907
    Instagram:
    Feb 2013
    When I turn the regulator knob clockwise it increases the PSI. And counter clockwise decreases the PSI. I turned the knob counter clockwise to the point the knob was going to fall off but still can't get the PSI to decrease..
    Should I turn on/open up the valves all the way on my torch or something?
    Feb 2013
    Oh my god, I GOT IT!!!!!!! yayay!! thanks soooo soo much
  1. Need regulators
    By bostonbull04 in forum Member's Glassifieds
    Last Post: 12-13-2011, 04:51 PM
  2. regulators
    By rp1313 in forum Member's Glassifieds
    Last Post: 04-10-2009, 04:50 PM
Tags for this Thread
