Results 1 to 6 of 6
Thread: FS: Brand new J Howard model Herbert Arnold with fresh custom tune
    fingerlakes, NY
    Icon4 FS: Brand new J Howard model Herbert Arnold with fresh custom tune
    title just about says it all!
    3100$ signed +delivered
    txt me at 315.560.6110 for a faster response and questions (i haven't been checking in too often)
    this torch has only been used long enough to fully tune it to my specs. if you've been thinking of getting a new 40mm herbie, this is the one to get. improved air configuration, and special air tuning for softer buttery flames. fully adjustable centerfire oxy: this is what really makes my custom model special - take the old school pin point flame and add the new style's adjustment knob. want a hotter flame?, put a jet of oxygen right up the middle of a raging flame. reducing your colors? open the knob and listen for the sizzling sound and watch the haze burn right off - it works like a blue knob on a gtt. want to run higher oxygen pressures but don't want the spastic centerfire? close the knob a little and settle her down. with a custom tune, i don't just adjust your hex keys, i tune your torch from scratch and balance it to run a range of pressures, giving you a better top end and a more adjustable customizable torch. i put a little more propane in your centerfire so you can get a little more ooomph out of it when you use the blue knob. then i spend a day working with it, using COLOR, and i make fine adjustments to it until it works just right. the tiniest adjustments make all the difference on these torches. at the factory, they are tuned by eye so they look like they run right, which they usually do. this is a performance tune optimized for american style glassblowing with color. use the search to read reviews on tunings i've given. no it does not come with a pressure reducer, but it will come tuned to one
    Dec 2011
    Default Re: FS: Brand new J Howard model Herbert Arnold with fresh custom tune
    Aww man stop your making me drool wish I was able to grab this glws should go quick and maybe one day...
    fingerlakes, NY
    sold
    Aug 2011
    Eugene, Or
    As my wifey often says, that was quick.
    Distributor of Gentec Products for the Glass Blowing Industry
    Contact me for everything Gentec!
    Eric F.
    Area 541 LLC
    Eugene, OR
    (541) 335-9907
    Instagram:
    Apr 2010
    Bloomington, IN
    New record
    ABR IMAGERY
    812-339-0147
    866-342-4764
    Twitter: @ABRDave
    Instagram: http://instagram.com/abrimagery
    western MA
    J's got the moves..................
  1. Custom Herbert Arnold 65mm - $7200 OBO
    By dreadlion in forum Member's Glassifieds
    Last Post: 04-10-2016, 02:50 AM
  2. Herbert Arnold 40mm Zenit torch Pro model in White E bay
    By Jah Kno in forum Member's Glassifieds
    Last Post: 05-10-2015, 06:37 PM
  3. Replies: 8
    Last Post: 04-01-2013, 11:45 PM
  4. Brand new Herbert Arnold ID chuck 100mm-200mm for bench or lathe
    By mindblowingglass in forum Member's Glassifieds
    Last Post: 11-03-2010, 09:23 AM
  5. Herbert Arnold 65 ml propane model with reg
    By Racer X in forum Member's Glassifieds
    Last Post: 05-28-2009, 10:00 AM
Tags for this Thread
