Re: Brass Gong Joint Holders
I bought a set of 14mm from you this summer and just really started using them. They work well, but the glue you used on the brass ends where they connect to the handle has quickly given out, where when in use doesn't hold and the end spins free or comes right off. It also smokes filling up inside my piece where when worked it leaves a burnt dichro look with gritty texture. I was wondering what can be done, like I said they have only been used a handful of times. Otherwise great tools!
Why not thread them in from the start. Glue sounds sketch, I have his v cutter and a soffie push I love using for push bowl bubs.
I never ordered these as I use a glass joint with no prob.
HI Neddo,
We make all repairs to our tools 100% Free of Charge. To get the burnt gritty texture look off the brass piece we recommend putting the handle end into a cordless drill and to spin the tool while holding a "RED" Fine scouring pad around the brass while spinning and it will shine up the Brass to Look like new . I will PM you about shipping the tool back to have it Repaired Free of Charge We will cover all Shipping Charges. We Use a Ultra High temperature Adhesive that only comes off with water so if you tried using water to clean the brass or soaked it etc. the Adhesive will come off. If I remember right, Your located in Orange, VT correct? We can have your tool repaired and sent back to you by next week
That is a great customer service policy. I just decided to buy tools from you when I'm shopping again because of that post.
Thank you StrawHat,
We really appreciate it !! Ttys!!
StrawHat Art Glass
Few left @ $75 each
4 Qty: 14mm Gong Joint Holder- Holds 14mm Female Glass joints
2 Qty: 14mm Gong Joint Holder- Holds 14mm Male Glass joints
Ive had only one issue with my bowl push. The sofi doesn't have the same pressure as the blastsheild due to the small hole. It wont blow out mouth pieces. It does blow rballs up great tho!
Melting wax one candle at a time
Thanks for the input chill,
I will def start making the sofi holes bigger on my next Bowl push /sofi productions to get some more pressure flow.
chillrelaxglass
Thanks lmk when that happens ill gladly take another! Top shelf tools,Great shipping,and customer service!
Now Have @$75 each:
-4 Qty: 10mm Gong Joint Holder- Holds 10mm Female Glass joints
-4 Qty: 10mm Gong Joint Holder- Holds 10mm Male Glass joints
-4 Qty: 14mm Gong Joint Holder- Holds 14mm Female Glass joints
-4 Qty: 14mm Gong Joint Holder- Holds 14mm Male Glass joints
-4 Qty: 19mm Gong Joint Holder- Holds 19mm Female Glass joints
-4 Qty: 19mm Gong Joint Holder- Holds 19mm Male Glass joints
Any 4 sizes @ $ $285
All 6 sizes 10mm,14mm&19mm in Male and Female @ $420
Free Shipping
I was gonna buy but am worried about the glue issue.....Did you thread them?
anyone know whats up with this guy, sent him money like 2 weeks ago, said he was ready to ship, havent heard from him since. why does this keep happening to me?
HI Bugz,
Sent you a PM with updated info. Sorry for the delay in response.
I want to buy some im worried about the glue tho......Did you remedy this?
chillrelaxglass
The New Threaded design will be out in the next few weeks
Few left @ $75 each
2 Qty: 14mm Gong Joint Holder- Holds 14mm Female Glass joints
2 Qty: 19mm Gong Joint Holder- Holds 19mm Male Glass joints
2 Qty: 19mm Gong Joint Holder- Holds 19mm Female Glass joints
2 Qty: 10mm Gong Joint Holder- Holds 10mm Male Glass joints
2 Qty: 10mm Gong Joint Holder- Holds 10mm Female Glass joints
hey man, I wanted to sell mine back to you because I didn't like them and one came unglued first day I used it. First you said you'd buy 'em back, then when I tried to get details you completely stopped responding. I also spent over $20 sending you those prototypes you mistakenly sent me... twice! I never heard from you again, I thought you'd at least say thanks or something!
Can you put threads on your existing tools? Or I'd have to buy new ones.
Hi TREX,
Sorry if I lost contact with you. I am going to start threading all of my tools, so send them back to me and I am going to thread the other ends of them as well. This way you can put counter balance weights on the ends . No Worries I will Thread them free of charge and ship them back for you. PM'D you shipping info
T-Rex
By Simian in forum Member's Glassifieds
Last Post: 09-12-2013, 06:26 PM
By kultureglass in forum Vendor's Glassifieds
Last Post: 09-04-2013, 03:59 PM
By kultureglass in forum Member's Glassifieds
Last Post: 07-09-2013, 03:58 PM
Last Post: 06-06-2013, 09:11 AM
