Stuff and Puff
I am trying to not get caught up in a topical phase so I need to start employing some more advanced techniques. stuff and puff is a really interesting one that I wish to learn. in theory I know how to do it but my first session ended with no successful implements. most of the time I keep having the colored gather stick to the walls because there isn't enough room. my first question is should I skip the bullcrap and up the size of my tubing to like 38 or is there another way to do it? I can use any tips you feel free enough to share and like always I appreciate the input. Glad to be apart of this free information site..
Re: Stuff and Puff
Ive used 32 medium wall with good success, I found anything smaller i touch the sides and muff it up. I have not tried any sizes larger than that atm. I love this tech, specially with reactive colours.
Re: Stuff and Puff
i don't think its practical with 32. ive been using 38 or bigger. get everything really hot. i have problems if the stuff cools before the puff. even if you touch the wall on accident if its hot enough you should be able to just blow it out.
Re: Stuff and Puff
I like solid marble style blow outs better. Push a quarter ,half a rod of color up to some 25 or bigger solid rod.
Then gather up and push a dent where your color slabs are, yes I like to layer them. Add large heavy wall blowtube 12,16, hw
Heat up whole solid mass and blow a bubble.
Re: Stuff and Puff
I used to do a lot of stuff n puffs. I would use a tube of 50x5mm open on both ends and about 6 inches long with a solid handle on the side. So it looks like a T. I could get the cleanest and fastest results that way. But the way Jr23 explains above is how I now do it after seeing Max Polin (MNP) do the same. MUCH cleaner look and just as fast using 40mm rod you will get more tubing too.
Re: Stuff and Puff
a variation, or i am not sure its a variation, but for striking colors like exp green or amber purple, its cool to take a rod of your striker and evenly mash it up against clear, or something else you want on top. evenly spin and mash together till you have a disk you can puff from whatever end you want to be the inside.
you will shank me later
FifDeez
Re: Stuff and Puff
I use them for layer combs I can get great layer tube and no lines or haze when working dap. I buy simex rod for this tech.
No cleaner tech tell your ready to buy a crucible and play with the big dogs.
Re: Stuff and Puff
i just started doing this recently, it does seem rather bomb.
and simax or bust! i'm ordering glass from 2800 miles away lately cuz i cant get reliable simax locally.
FifDeez
Re: Stuff and Puff
do you have a video demonstrating this solid marble tech? it sounds good. I would like to see it..ill try to you tube it...
By UmaJulz in forum Glass Discussion
Last Post: 03-27-2008, 02:57 PM
By Gibsons Glassworks in forum Glass Discussion
Last Post: 07-24-2007, 10:08 PM
