Quartz Joints 14/23 male
So I have been looking everywhere for quartz joints in 14/23....All I can find is 14/35??? Is that the only size they make? Im looking to put a FEMALE 14/23 boro joint to MALE QUARTZ 14/23???
I checked the following places
Ace glass
TGP
GM associates
All I see is 14/35 for sale is that the only size they make?
http://gmassoc.thomasnet.com/viewite...nner-joints-2?
Melting wax one candle at a time
Re: Quartz Joints 14/23 male
Can someone just tell me if they make quartz joints that fit boro joints?
Dom those do say 14/20 so it will fit a 14/23 boro female?
I have 14/20 quartz joints. They will fit any 14mm female, there may be a difference in the length of the ground part but they will fit. PM me. I do a lot with quartz.
How much? I'm interested also^
14/20 joints are $12.00 each. 19/22 joints are $13.00 each. I don't know what you want them for, but I work quartz all the time. I would like to give you quotes on anything you want out of quartz. Visit my website kingofquartz.com and you can see what I can do.
Is that a boro nail or is there colored quartz?
Colored quartz. I don't make any boro nails. I am making an improved version of the domeless/direct inject "daisy top" I call it the "Crown Top". On the KQ236-1419 universal nail I use 5x7mm for the stem & 14x18mm for the cup. (For 14mm & 19mm male joints) The cup is pushed in and has 6 slots. The slots are not cut through to the outside of the cup they are all inside of the cup so you are not drawing in outside air. On the KQ236-19 I use 7x10mm for the stem and 18x22mm for the cup. The cup has 8 slots. (For 19mm male joints only) This one is not on the website yet, it should be there by the end of the day. kingofquartz.com
Reason: Changed wording
Wow. Learned something. Colored quartz! Wonder why nobody uses it for buckets and domelesses nails? I wouldn't mind some joints, and a little colored to test out. I'm in michigan. Anyway we could meet up? I would love to check out your stock and pick your brain a little.
All I have 8x10mm red quartz. There are very limited sizes available. It is also difficult to use. The wall thickness is very uneven and it does not melt the same as clear quartz, that is why all of my domeless nails are made with clear. Call me 269-287-0683
That's the other side of the state, but I'll still call ya.
papa jim do you make your fittings? how thick? do you make females too? prices on those, including 10m please and thank you
p.s. your automated lathe videos are a trip!
Very neat!!!Have to get some nails from you very nice!!
we sell them. but a bit behind. thc has doubled our taper production!
yes there are 1420s, and 23s. boro to quartz is a bit tough. i have fused both without cobalt but it was larger tubing. 45x55 boro and 50x55 qutartz. stress becomes an issue. i spin so i have much more time to anneal than fixed torches
Hi guys, sorry to bump such an old thread, just wanted to keep everything together. I'm also looking for 14/23 and 10/20 quartz joints, male and female, and though not entirely necessary, I'd ideally like them to be produced in the US/CAN/EU. If anyone could point me in the right direction that'd be great. Thanks!
I have 10/18 & 14/20 quartz joints on my website for $10.00 each. They are imported.
kingofquartz.com
Hey papa Jim What kind of material length is there beyond the joint? Are they like most boro joints about 5 inches long in total?
By The Lorax in forum Member's Glassifieds
Last Post: 06-21-2014, 07:33 AM
By Sandslash in forum Member's Glassifieds
Last Post: 12-27-2013, 10:34 PM
By burton13order in forum Member's Glassifieds
Last Post: 09-06-2013, 05:58 AM
Last Post: 04-28-2012, 04:00 PM
Last Post: 12-06-2009, 02:14 PM
