Page 24 of 24 FirstFirst ... 14 19 20 21 22 23 24
Results 461 to 463 of 463
Thread: Flower power!
  1. #461
    May 2014
    Austin Tx
    Default Re: Flower power!
    Quote Originally Posted by gypsea View Post
    Perhaps itís due to the clear glass that you are applying the stringer to not being hot enough when you lay the stringer on it.
    Hmmm. Interesting. I usually lay it colder.. I'm actually laying these while warmer because the gold fume causes the stringer to curl and not stick to the glass. Once laid, they really dont seem any different, but this is something I havent tried correcting so I'll do that on the next one thanks!
    Nah, nah. See, I meant to do that.
  2. #462
    Apr 2012
    Quote Originally Posted by paulsafo View Post
    Clear curling in, or down if you will, gathering at the end of your stringer...do you layer inclear ...like around the stringer...could be that? It has to be clear, imo.
    Nip the end of the stringer.
    Based on the quality of those I really shouldn't be trying to give advice, much better than my flowers.
  3. #463
    GA / VA
    Not super hot, I lay them fairly cool too, I was just wondering if due to temp, perhaps the stringer was not imbedded Into the clear and was lifting up at a small point in the center of the petal line causing the hollow part. It’s just wondering outloud; I don’t have the actual solution/reason.
  1. sound power
    By harpentuan in forum Glass Discussion
    Last Post: 07-18-2008, 07:54 AM
