Generally, it is best to put together your own collection of equipment. Depending on who offers the kit, sometimes instead of a discount for buying everything at once, the kit is sold at a premium.
Since the Hot Head is considered by some to be a starter torch (but there are established bead makers/murrini makers who only use Hot Heads, and bead makers who use the Hot Head as a lower temperature torch for adding decorations), perhaps the best source for a Hot Head is the classified section of bead making forums. Most forums require you to register in order to see the classified sections.
The most active bead making forum is LampworkEtc. (
www.lampworketc.com )
A real Hot Head is about $40. Knock-off hot heads are just brazing torches and are about $20. However, if you want to experiment before getting an official Hot Head, try going to your local auto parts store. A few years ago, you could get the torch on which the Hot Head is based (the Mag Torch MT245) for less than $10 at Auto Zone. The MT245 is commonly available, and you probably could find it at WalMart.
The difference between an official Hot Head and a brazing torch, as far as I know, is in the orifice plate. The official Hot Head has a recessed orifice and also has a screen, and tends to be a bit cooler because the screen reduces the gas flow slightly.
"Spectrum 96" can be worked on a Hot Head. COE 90 is also a popular application for the Hot Head. For example, Glaskolben, which are pre-pulled points most often used to make ornaments, are COE 89, and so COE 90 colors can be used. Besides Spectrum, COE 96 is commonly available in the Uroboros and Reichenbach brands.
Regarding Devardi: I belong to a group called the Silicon Valley Fireflies, and one of the members started out as a glassblower. He made his own kiln for preheating Devardi glass, and as far as he is concerned, pre-heated and/or annealed Devardi glass works for him just fine.
