Re: Check valve on EX20?
backpressure isn't really an issue. when i was running my midrange off of 3 ex15's, (8lpm machines) i'd turn the lpm down to 6 on each (better purity) and during the times i was using the premix rider (which sips oxy) i never bothered to turn down the output on the oxycons. so long as there is some flow, you can have your oxycon set to 8lpm, only use 3lpm and it won't hurt anything.
when there is no flow (like a kinked hose or you took a safety break and didn't leave the oxy valve on torch cracked), that's when you'll run into some troubles eventually.
