if your o2 is delivered in pulses the solenoid valves most likely need to be replaced. if you follow the lines from the compressor they will lead to the filter, one line will go to the valves and the other will go to the filter. some machines have no filter at all. i believe the valves in these machines are not air operated so if you o2 output pulses its not caused by the compressor feed pressure, compared to the resperonics machines. the resperonics have air operated valves so if the compressor starts under performing the valves will not actuate.
