Re: Encalmo
i imagine the piece is getting too cool as you are working it. causing stress. hard to say without more details about when / how it cracks
Re: Encalmo
The hotter and faster you work the less chance for cracks, and work left to right or vise versa, trying to never go backwards once you've moved forwards. Try not to cross the piece through the flame once worked, again it reverts back to my previous comment, work like writing ( left to right). Even heatbase . consistent wall thickness's
your linework is naive
maybe try some fuming?
Re: Encalmo
Thanks for weighing in so quickly you two! That's kinda what I figured the issue was. My speed is definetly getting better but still has room for improvement. I guess one of the reasons I asked here is I've asked locals none of them do a ton of encalmo but they said it could be the colors I'm using. They never went into it anymore or offer any type of explanation. I only use colors in encalmo without warnings of odd coe., or that are known for not working well with others. Are there any general rules to know when picking colors to use in an encalmo?
Re: Encalmo
forevergrateful
every color will have a working guide of sorts, best to just understand each individual color. i havent come across too many that are incompatible.
Re: Encalmo
looks like there's still some stress in the bowl area from the push (picture 2), that seal isn't too far from there either. Maybe some un even walls "sealed the deal". Just my guess.
Re: Encalmo
Sparko
I generally do polish my bowls not sure how I missed that one. And then didn't notice it after the fact.
Re: Encalmo
When picking colors, pick colors that have a similar viscosity when melted. Black and white for example, can be difficult to work together.
Re: Encalmo
i'd suggest flame annealing after adding each encalmo section, that section and the one next to it. just for 30s to a minute.
you will shank me later
FifDeez
Re: Encalmo
When you can, grab a big old chunk of broken stuff and look at the wall thickness. I have always learned a lot from my scrap, more so than my successes. Post a pick if you can. We might learn a bit about you problem.
Good luck. Be well!
Re: Encalmo
Hey all thank you so much for all the responses! I gotta say I don't have FB and it took me awhile to find this forum. Prior too finding this forum there was 3 or 4 locals that were willing to answer questions and 1 or 2 people I follow on Instagram. However I was usually meet with snide comments and anger that I would waste their time asking a question. So thank you! I knew there had to be more good people in this scene!
Re: Encalmo
fUmEsNiFfEr
That makes sense thanks for the tip!
Re: Encalmo
hashmasta-kut
That makes a lot of sense I can't believe I never thought of that.
Re: Encalmo
kilgroth
Good luck. Be well!
I actually went to dig through my graveyard to do this yesterday. However I forgot I through it all in a 5 gallon bucket. The only one I had were I didn't have to dig through a bucket of broken glass to look at was definetly from accidentally splashing it with the flame when taking the blow tube off. When or if (wishful thinking lol) it happens again I'll definetly post a pic
Re: Encalmo
White and any dark color, can be a bitch.
Sometimes white will not have all the tin melted into the batch... It just acts gritty and tends to break off dark color, especially cobalt colors.
If you have a suspect color, try to enclamo over clear, so you have a clear core under the suspect color. It helps to keep it all happy.
By SexualHarassmentPanda in forum Glass Discussion
Last Post: 12-18-2012, 03:15 AM
By Alex K in forum Pics, Galleries, and Websites
Last Post: 10-02-2008, 08:20 PM
