Results 1 to 12 of 12
Thread: Glass
    Default Glass
    New to blowing glass and was wondering if the import clear tube was any good for practicing making pipes and other small stuff or should I just go ahead and buy the nicer brands like sumac and what sites have the best deals on glass. Thanks in advance
    Nov 2006
    Default Re: Glass
    for sure, and but its imported from China or European producers too. Price reflects quality.
    you will shank me later
    Quote Originally Posted by FifDeez View Post
    Default Re: Glass
    What cheap tubing would you reccomend for practicing?
    Sauk Rapids, Minnesota
    Default Re: Glass
    Just remember that techniques (like fuming) won't work the same way on quality glass. You also may have compatibility issues with cheap glass that you won't with quality.
    Nov 2006
    Default Re: Glass
    Quote Originally Posted by coltonwalters49 View Post
    Only tried Schott, Simax and Kimble. I've got one rod of Chinese clear, it seems fine. All the others are good stuff usually.
    Default Re: Glass
    When i bought my first few cases i found that you could get smaller cases of Simax which helped me try it out. I use Schott for punties and blowtubes and that works great, not too expensive. The Chinese i have all has to be worked into the heat slowly, except for some colors like black and cobalt. dont have a buncha chinese but i really didnt notice a HUGE difference between the 25x4 chinese and 25x4 Schott. i havent fumed the Chinese clear alot but for practicing i dont see why not. I probably should have started with more Chinese to save money but i wanted American glass when i started.
    Default Re: Glass
    Who do you reccomend ordering from for best prices and customer service
    Jan 2006
    Belfair, Wa.
    Default Re: Glass
    https://lampworksupply.com/
    What do you plan on making?
    "demanding respect doesn't get you shit
    love your fellow man" Mute
    https://www.facebook.com/brian.cesario.56
    Default Re: Glass
    @fUmEsNiFfEr pipes carb caps eventually move onto rigs and smaller tubes
    Default Re: Glass
    Mountain Glass Arts, UST, Frantz are good customer service
    Nov 2009
    Sonoma County, CA
    Default Re: Glass
    Mountain Glass has always treated me very well, +1 for them.
    @mwcglass
    Aug 2012
    Ny
    Default Re: Glass
    Clear glass tends to all be similar , except the fume colors you can achieve.( Like everyone already mentioned )
    Most people ( 80%?) could not melt a clear tube and tell you what brand it is. It all melts and looks the same. More experience and you can tell, but it's a moot point untill you are making high end/complex glass.
    Color is a different beast. Color is more complex, has more ingredients and takes more to make. Cheap color tends to run a higher chance of failure, where it will crack, turn color, or do any number of things. The quality from the cheaper options has gone way up compared to ten years ago. So again I would not be afraid of the cheap options. You might have 1/4 or 1/5 the color choices from cheapr sources. They all seem similar. I would not shy away from any color if it's what I'm looking for. (Reading reviews can help)
    I will say boro bars /origin glass (American) is made with a powder and works slightly different. It still works fine with everything else when you treat it correctly. Totally worth the $ per pound.
    With color, I try to keep my money in country, and I am more likely to get what I asked for that way. Coustermer service is also a plus.
    See this thread, the cheap option was fine the last few orders, but the current batch is not as advertised. The cheaper color is usually made on a bigger scale, with more product and lower q.c. as modus operandi.
    http://www.talkglass.com/forum/showt...n-Striking-Red
    This next link is the best way I can help get some one started.
    http://www.talkglass.com/forum/showt...ght=Read+first
    Not really the answer the o.p. was asking , but I imagine it's relevant.
  1. Replies: 8
    Last Post: 07-09-2014, 10:20 PM
  2. kind of cut glass with soft glass on Boro glass
    By alain villechange in forum Pics, Galleries, and Websites
    Last Post: 11-08-2012, 10:46 AM
