Results 1 to 4 of 4
Thread: Cutting tubing
    seattle
    Default Cutting tubing
    I have the need to cut 25 mil tubing.
    -25 by 4mm tubing to be exact. and some 50mm by 9mm.
    -Any advice from anyone on this subject?
    -I am thinking that scoring it 360 degrees and then heating it with a very hot kiln element wire to stress it would work.
    -I do not want to water jet cut it.
    -Is there a way to cut tubing with sound? i have heard of this.
    -Maybe lasers? what kind of laser would I need?
    -This is a link to some ideas, I am not fired up by these search results
    https://www.google.com/search?client...ing+with+sound
    Thank you for your help.
    -I have 600+ cuts to do per month and I do not want to have to clean up after the mess that a wet saw would make. (inside and outside of the tubing).
    Im offering free 1 hour lampworking lessons in the Alki and west Seattle area.
    Jan 2015
    Default Re: Cutting tubing
    This sounds like way overkill when something like a wet saw will cut tube just fine with a decent blade.
    "Don't get me wrong gtts are nice, but I'm more about that Issac Hayes smooth talking flame over the "come here boy you got a purty mouth" prison sex flames that gtts are known for."
    Aug 2012
    Ny
    https://m.youtube.com/watch?v=ClpONnKyjnI
    This is the way they teach at Salem.
    Here it is on a lathe, (second link) but I have seen it done with more finesse, you only need one scribe around the glass before you heat and spray the water.
    https://m.youtube.com/watch?v=_payhEVYz3Q
    I have used it clean on 75x5 , 50x5 and 50x7.... Not sure about 50x9? I would use a lathe only , if it went South you might loose a finger or hand...
    Someone on Instagram just posted a " how to " on this method the last day or two, I can't recall whom it was.
    That said, I have to help make thousands of cuts a month. We use a wet saw and dunk cut tubes into water , and plunge out the inside of each. Im lucky I only have to cut once in a blue moon. (I get to test melt color mostly )
    Cuts from just today...
    One of
    these jaws tools makes a nice strait scribe
    seattle
    oooooooh 75 x 5. HOT!
  1. Help cutting standard wall tubing
    By Bugzy1972 in forum Glass Discussion
    Last Post: 05-28-2011, 07:27 PM
Tags for this Thread
