Bench Rollers
Bench Rollers
Bench rollers are used to hold heavy glass on while you spin it. They come in several different types including the two wheel Yoke style and the multiple wheel Bench Roller. They provide quality support for pieces that must be heated or rotated uniformly and can take a large amount of pressure off of the wrists while working with heavy pieces. To buy new rollers you should expect to pay between $80-$150. Although it is possible to make your own.
Bench rollers are made up of a base, an adjustable or non-adjustable center, and the rollers, which also may be adjustable.
The base can be magnetic, to hold it in place. If it is not magnetic it needs to be large enough and heavy enough to remain stable.
The center is usually adjustable between 6-12 inches.
The rollers usually consist of wheels on ball bearings to ensure a smooth turn. These are also adjustable to accommodate different sizes of rod or tube.
