Fuji Kiln Controller - How to program
Here are some directions on how to program the following Fuji kiln controller. This type of controller is programable to have ramp and soak cycles, or can simply be used to select and hold at a specific temperature.
FUJI PXR3 NEW STYLE
PROGRAMING YOUR CONTROLLER FOR PROGRAM #1
PUSH AND HOLD THE SEL BUTTON UNTIL THE DISPLAY READS STAT.(if it does not read stat it will read P then use arrow down until you get to SV1 which actually looks like su-1 on the digital read out) PUSH THE DOWN ARROW TWICE UNTIL THE DISPLAY READS SV1. PRESS SEL ONCE - ENTER YOUR 1ST TARGET TEMP - PRESS SEL ONCE AGAIN. ARROW DOWN ONCE TO 7N1R - ENTER THE RAMP TIME FOR SV1 - PRESS SEL AGAIN, ARROW DOWN TO 7N1S - ENTER YOUR SOAK TIME FOR SV1 - PRESS SEL ONCE.
ARROW DOWN ONCE TO SV2 - ENTER YOUR 2ND TARGET TEMP. - PRESS SEL ONCE, ARROW DOWN ONCE TO 7N2R - ENTER YOUR RAMP TIME FOR SV2. - PRESS SEL ONCE, ARROW DOWN ONCE TO 7N2S - ENTER YOUR SOAK TIME FOR SV2. - PRESS SEL ONCE.
AND SO ON FOR SV3 AND SV4 TO COMPLETE PROGRAM #1
PROGRAMING YOUR CONTROLLER FOR PROGRAM #2
SV5 THROUGH SV8 ARE DESIGNATED FOR PROGRAM #2. FOLLOW THE ABOVE INSTRUCTIONS BUT ENTER VALUES FOR SV5 THROUGH SV8 AND YOU WILL HAVE YOUR 2ND PROGRAM.
INSTEAD OF HAVING 2 SEPERATE PROGRAMS, YOU ALSO HAVE THE OPTION OF HAVING ONE LONG PROGRAM THAT CAN HAVE UP TO 8 TEMPS, RAMPS AND SOAKS. TO DO THIS, JUST PROGRAM ALL THE VALUES FOR SV1 THROUGH SV8. THEN SEE BELOW ABOUT SELECTING PROGRAM #3. THE CONTROLLER SEES PROGRAM #1 AS SV1 THROUGH SV4, PROGRAM #2 AS SV5 THROUGH SV8, AND PROGRAM #3 AS RUNNING "BOTH PROGRAMS" BACK TO BACK (IF YOU CHOOSE THE THIRD OPTION, OF COURSE, IT IS ESSENTIALLY ONE LONG PROGRAM).
PROGRAM SELECTION
IF YOU WANT TO RUN THE SAME PROGRAM YOU RAN LAST TIME SKIP THIS STEP AND GO TO "RUNNING A PROGRAM" BELOW.
IF YOU NEED TO CHANGE THE PROGRAM YOU RAN LAST TIME OR VERIFY WHICH PROGRAM WILL RUN: PUSH AND HOLD THE SEL BUTTON UNTIL THE DISPLAY READS STAT. PUSH THE DOWN ARROW ONCE SO THE DISPLAY READS PTn. PUSH SEL BUTTON ONCE - THE LAST PROGRAM YOU RAN (1 OR 2) WILL BE DISPLAYED. PRESS THE UP OR DOWN ARROW TO DISPLAY THE PROGRAM YOU WISH TO RUN.
NOTE: ARROWING TO 3 WILL RUN BOTH PROGRAMS BACK TO BACK. DO NOT USE #3 UNLESS YOU HAVE PROGRAMMED A SINGLE 8 SEGMENT PROGRAM
LEAVE IT ON 1 OR 2 FOR ABOUT 30 SECONDS UNTIL THE DISPLAY GOES BACK TO THE TEMPERATURE IN THE KILN.
RUNNING A PROGRAM
PUSH AND HOLD THE SEL BUTTON UNTIL THE DISPLAY READS PROG. PRESS THE SEL BUTTON ONCE SO THE DISPLAY READS OFF. PUSH THE UP ARROW ONCE SO THE DISPLAY READS RUN. THE WORD "RUN" WILL BLINK - PUSH SEL TWICE - RUN WILL STAY LIT LEAVE IT THERE AND IN ABOUT 30 SECONDS THE DISPLAY WILL GO BACK TO THE TEMPERATURE IN THE KILN - YOUR PROGRAM IS NOW RUNNING.
WHEN THE PROGRAM IS COMPLETE THE DISPLAY WILL SHOW THE TEMP IN THE KILN UNTIL YOU TURN IT OFF.
