Msds silver
Material Safety Data Sheet
Silver
ACC# 20770 Section 1 - Chemical Product and Company Identification
MSDS Name: Silver Catalog Numbers: S163-10 Synonyms: Argentum. Company Identification:
             Fisher Scientific
             1 Reagent Lane
             Fair Lawn, NJ 07410
For information, call: 201-796-7100 Emergency Number: 201-796-7100 For CHEMTREC assistance, call: 800-424-9300 For International CHEMTREC assistance, call: 703-527-3887
Section 2 - Composition, Information on Ingredients
CAS# Chemical Name Percent EINECS/ELINCS 7440-22-4 Silver 100 231-131-3
Section 3 - Hazards Identification
EMERGENCY OVERVIEW Appearance: white solid. Caution! May cause respiratory and digestive tract irritation. May cause eye and skin irritation. Danger of cumulative effects. Target Organs: Kidneys.
Potential Health Effects Eye: May cause eye irritation. Skin: May cause skin irritation. May cause skin discoloration. Ingestion: May cause irritation of the digestive tract. Effects may be cumulative. Ingestion of silver compounds may cause abdominal pain, rigidity, convulsions and shock. Inhalation: May cause respiratory tract irritation. Inhalation of fumes may cause metal fume fever, which is characterized by flu-like symptoms with metallic taste, fever, chills, cough, weakness, chest pain, muscle pain and increased white blood cell count. Chronic: Chronic inhalation or ingestion of silver salts may cause argyria characterized by a permanent blue-gray discoloration of the eyes, skin, mucous membranes, and internal organs. This malady results from the accumulation of silver in the body.
Section 4 - First Aid Measures
Eyes: Flush eyes with plenty of water for at least 15 minutes, occasionally lifting the upper and lower eyelids. If irritation develops, get medi cal aid. Skin: Flush skin with plenty of water for at least 15 minutes while removing contaminated clothing and shoes. Get medical aid if irritation develops or persists. Wash clothing before reuse. Ingestion: Do NOT induce vomiting. If conscious and alert, rinse mouth and drink 2-4 cupfuls of milk or water. Wash mouth out with water. Get medical aid if irritation or symptoms occur. Inhalation: Remove from exposure and move to fresh air immediately. If not breathing, give artificial respiration. If breathing is difficult, give oxygen. Get medical aid if cough or other symptoms appear. Notes to Physician: Treat symptomatically and supportively.
Section 5 - Fire Fighting Measures
General Information: As in any fire, wear a self-contained breathing apparatus in pressure-demand, MSHA/NIOSH (approved or equivalent), and full protective gear. During a fire, irritating and highly toxic gases may be generated by thermal decomposition or combustion. Non-combustible, substance itself does not burn but may decompose upon heating to produce corrosive and/or toxic fumes. Extinguishing Media: Substance is noncombustible; use agent most appropriate to extinguish surrounding fire. Use water spray, dry chemical, carbon dioxide, or appropriate foam. Flash Point: Not applicable. Autoignition Temperature: Not applicable. Explosion Limits, Lower:Not available. Upper: Not available. NFPA Rating: (estimated) Health: 1; Flammability: 0; Instability: 0
Section 6 - Accidental Release Measures
General Information: Use proper personal protective equipment as indicated in Section 8. Spills/Leaks: Vacuum or sweep up material and place into a suitable disposal container. Clean up spills immediately, observing precautions in the Protective Equipment section. Avoid generating dusty conditions. Provide ventilation.
Section 7 - Handling and Storage
Handling: Wash thoroughly after handling. Wash thoroughly after handling. Avoid contact with eyes, skin, and clothing. Keep container tightly closed. Avoid ingestion and inhalation. Use with adequate ventilation. Storage: Store in a tightly closed container. Store in a cool, dry, well-ventilated area away from incompatible substances. No special precautions indicated.
Section 8 - Exposure Controls, Personal Protection
Engineering Controls: Facilities storing or utilizing this material should be equipped with an eyewash facility and a safety shower. Use adequate ventilation to keep airborne concentrations low. Exposure Limits Chemical Name ACGIH NIOSH OSHA - Final PELs Silver 0.1 mg/m3 TWA 0.01 mg/m3 TWA (dust) 10 mg/m3 IDLH (dust) 0.01 mg/m3 TWA
OSHA Vacated PELs: Silver: 0.01 mg/m3 TWA Personal Protective Equipment Eyes: Wear appropriate protective eyeglasses or chemical safety goggles as described by OSHA's eye and face protection regulations in 29 CFR 1910.133 or European Standard EN166. Skin: Wear appropriate protective gloves to prevent skin exposure. Clothing: Wear appropriate protective clothing to minimize contact with skin. Respirators: A respiratory protection program that meets OSHA's 29 CFR 1910.134 and ANSI Z88.2 requirements or European Standard EN 149 must be followed whenever workplace conditions warrant respirator use.
Section 9 - Physical and Chemical Properties
Physical State: Solid Appearance: white Odor: none reported pH: Not available. Vapor Pressure: 100 mm Hg @ 1865 C Vapor Density: Not available. Evaporation Rate:Not applicable. Viscosity: Not available. Boiling Point: 2212 deg C Freezing/Melting Point:961 deg C Decomposition Temperature:Not available. Solubility: Insoluble in water. Specific Gravity/Density:10.5 Molecular Formula:Ag Molecular Weight:107.8682
Section 10 - Stability and Reactivity
Chemical Stability: Stable under normal temperatures and pressures. Conditions to Avoid: Incompatible materials, exposure to air. Incompatibilities with Other Materials: Strong acids, strong bases, ethyleneimine. Hazardous Decomposition Products: Irritating and toxic fumes and gases, silver fumes. Hazardous Polymerization: Has not been reported.
Section 11 - Toxicological Information
RTECS#: CAS# 7440-22-4: VW3500000 LD50/LC50: Not available.
Carcinogenicity: CAS# 7440-22-4: Not listed by ACGIH, IARC, NTP, or CA Prop 65.
Epidemiology: IARC Group 4: Substance nonclassifiable with regard to carcinogenicity.Tumorigenic :See RTECS Teratogenicity: No information found Reproductive Effects: No information found Mutagenicity: No information found Neurotoxicity: No information found Other Studies:
Section 12 - Ecological Information
Ecotoxicity: No data available. No information available. Environmental: Aquatic Fate: Sorption and precipitation processes are effective in reducing the concn of dissolved silver and result in higher concn in the bed sediments than in the overlying waters. Sorption by manganese dioxide and precipitation with halides are probably the dominant controls on the mobility of silver in the aquatic environment. Physical: Algae, daphnia, fresh water mussels, and fathead minnows were all found capable of accumulating silver; but the food chain was not an important route of silver accumulation for animals at higher tropic levels, suggesting no food chain magnification. Other: For more information, see "HANDBOOK OF ENVIRONMENTAL FATE AND EXPOSURE DATA."
Section 13 - Disposal Considerations
Chemical waste generators must determine whether a discarded chemical is classified as a hazardous waste. US EPA guidelines for the classification determination are listed in 40 CFR Parts 261.3. Additionally, waste generators must consult state and local hazardous waste regulations to ensure complete and accurate classification. RCRA P-Series: None listed. RCRA U-Series: None listed.
Section 14 - Transport Information
US DOT Canada TDG
Shipping Name: Not regulated as a hazardous material No information available. Hazard Class: UN Number: Packing Group:
Section 15 - Regulatory Information
US FEDERAL
TSCA
    CAS# 7440-22-4 is listed on the TSCA inventory.
Health & Safety Reporting List
    None of the chemicals are on the Health & Safety Reporting List.
Chemical Test Rules
    None of the chemicals in this product are under a Chemical Test Rule.
Section 12b
    None of the chemicals are listed under TSCA Section 12b.
TSCA Significant New Use Rule
    None of the chemicals in this material have a SNUR under TSCA.
CERCLA Hazardous Substances and corresponding RQs
    CAS# 7440-22-4: 1000 lb final RQ (no reporting of releases of this hazardous substance is requir
SARA Section 302 Extremely Hazardous Substances
    None of the chemicals in this product have a TPQ.
SARA Codes
    CAS # 7440-22-4: delayed, fire.
Section 313
    This material contains Silver (CAS# 7440-22-4, 100%),which is subject to the reporting requirements of Section 313 of SARA Title III and 40 CFR Part 373.
Clean Air Act:
    This material does not contain any hazardous air pollutants.
    This material does not contain any Class 1 Ozone depletors.
    This material does not contain any Class 2 Ozone depletors.
Clean Water Act:
    None of the chemicals in this product are listed as Hazardous Substances under the CWA.      CAS# 7440-22-4 is listed as a Priority Pollutant under the Clean      Water Act. CAS# 7440-22-4 is listed as a Toxic Pollutant under the Clean Water Act.
OSHA:
    None of the chemicals in this product are considered highly hazardous by OSHA.
STATE
    CAS# 7440-22-4 can be found on the following state right to know lists: California, New Jersey, Pennsylvania, Minnesota, Massachusetts.
California Prop 65
California No Significant Risk Level: None of the chemicals in this product are listed.
European/International Regulations European Labeling in Accordance with EC Directives Hazard Symbols:
     Not available.
Risk Phrases:
    R 33 Danger of cumulative effects.
Safety Phrases:
    S 37 Wear suitable gloves.
    S 45 In case of accident or if you feel unwell, seek medical advice
    immediately (show the label where possible).
    S 28A After contact with skin, wash immediately with plenty of water
WGK (Water Danger/Protection)
    CAS# 7440-22-4: 0
Canada - DSL/NDSL
    CAS# 7440-22-4 is listed on Canada's DSL List.
Canada - WHMIS
    This product has a WHMIS classification of D2A.
This product has been classified in accordance with the hazard criteria of the Controlled Products Regulations and the MSDS contains all of the information required by those regulations. Canadian Ingredient Disclosure List
    CAS# 7440-22-4 is listed on the Canadian Ingredient Disclosure List.
Section 16 - Additional Information
MSDS Creation Date: 12/12/1997 Revision #8 Date: 2/15/2008
The information above is believed to be accurate and represents the best information currently available to us. However, we make no warranty of merchantability or any other warranty, express or implied, with respect to such information, and we assume no liability resulting from its use. Users should make their own investigations to determine the suitability of the information for their particular purposes. In no event shall Fisher be liable for any claims, losses, or damages of any third party or for lost profits or any special, indirect, incidental, consequential or exemplary damages, howsoever arising, even if Fisher has been advised of the possibility of such damages.
